2005 S40 Tach reads too high
Old 10-02-2013, 12:47 PM
atikovi's Avatar
Default 2005 S40 Tach reads too high
I haven't driven the car over a month so I had to jump start it a few times. Don't know if that has anything to do with it but now the tach reads 1,000 rpm too high, and with the engine off, it points to 1,000. Can the tach be adjusted with a scan tool?
Old 10-02-2013, 05:14 PM
difflock54's Avatar
When you jump started it I trust you ensured you had the jump leads the correct way round, polarity wise! relative to the donor car / battery?
Old 10-02-2013, 05:38 PM
atikovi's Avatar
Problem stopped after I drove it this afternoon.
Old 10-02-2013, 06:41 PM
difflock54's Avatar
Good stuff.
Your CEM has probably reset itself.
Sometimes one needs to do that by holding the vehicles + and - battery terminals together whilst being disconnected from the battery approx 15-20 seconds.
Then you reconnect terminals to the battery.
Sir James
11-07-2012 03:38 AM
3s0x
03-22-2012 08:06 AM
3s0x
03-20-2012 07:07 PM
bid
06-09-2011 11:31 PM
Muskoka
10-23-2005 11:42 PM
Quick Reply: 2005 S40 Tach reads too high
