97 850 with high NO but not too high
Old Mar 15, 2012 | 02:41 PM
3s0x's Avatar
Default 97 850 with high NO but not too high
I just fail a smog check in California, my 97 850 has about 300,000 miles on it. It runs great with no check engine light. I did get a code a few moths ago for evap system. Will that effect NO levels? My levels at 15mph where 506 the max is 424, in addition at my last smog two years ago my NO levels where about 200. After decarbonizing it went down to 496. Cat was replaced a few years ago. Any suggestions, should i decarbonize again? Is it bad 02 sensors, one or both, or should I try something else?
sinclairPosts: 1Joined: Yesterday, 13:43
Old Mar 18, 2012 | 12:59 AM
gdog's Avatar
What engine (NA, LPT, HPT)? Don't think it does, but does your engine have an EGR valve? If it's clogged that could increase NO.
Inclined to think at that mileage most likely carbon buildup on piston tops; what did you do to de-carbonize?
Have you done a compression test?
Any current DTCs (is your Check Engine Light on)?
Old Mar 18, 2012 | 05:11 AM
Glad we don't have inspections. He said it has NO cel.
Old Mar 20, 2012 | 07:07 PM
3s0x's Avatar
i heard a hiss coming from the fuel pressure regulator, would that have anything to do with this problem.
Sir James
Nov 7, 2012 03:38 AM
3s0x
Mar 22, 2012 08:06 AM
omniahobo
May 8, 2010 12:24 AM
Eric
Jan 19, 2006 08:41 PM
Muskoka
Oct 23, 2005 11:42 PM
