Advice s40 2001
The 5 cylinder engines are completely different and not related to the 1.9L four cylinder engines in your 2001. It won't fit without a bunch of extra work.
What do you mean by "blown"? The normal failures in these engines are bent valves from a bad timing belt / VVT gear or warped head from an overheat. Damage from no oil has occurred but it's not normal.
