Cam position sensor s40t code po341
Old 07-16-2015, 12:25 PM
Bobby B769's Avatar
Unhappy Cam position sensor s40t code po341
I drove my car this am, (ran fine) and shut it off after 12-13 miles. When I tried ti start it later, it skipped a bit and didn't start. I scanned it and got an engine code of PO 341, indicating a malfunction of the cam position sensor A Bank 1 CKT Range/Perf. I'm getting a spark at the plugs when I pulled them, and there is pressure in the fuel rail, but it still doesn't fire. Any suggestions?
Old 07-17-2015, 06:43 AM
Hudini's Avatar
Check the compression. You want to rule out a damaged engine from a jumped timing belt.
If that checks good, measure the fuel pressure. You can have a little bit but not enough to run the engine.
Dragonhawk
02-25-2015 11:34 PM
A MAL3 NURSE
03-30-2012 11:00 PM
bhigdon101
02-08-2010 06:04 PM
phils94850
01-05-2010 10:07 PM
alviny
03-23-2009 07:25 PM
Quick Reply: Cam position sensor s40t code po341
