PCV valve damaged
Pcv system
thank you for you timely respond
i think the PCV valve is a component inside the PCV system but wht i dont know is, is it the same thing as the oil filter housing? i have been shown a diagram of the OIL filter housing and it is exactly similar to the one u sent....if it is the same think, i think thats exactly what i am looking for.
yes, u have a P1 model PCV box. the pcv box is part of the oil filter housing. is local under the intake manifold system. to replace that is not something DIY. It require some mechanical skill because it require to move the air box including the ecm away so that u get to it. It is not a difficult job. I m sure there are a lot of great auto tech in your country and they should be able to fix it for u.
outdoor7or24
09-17-2008 06:51 PM
