Sponsored by:
Sponsored by: DashLynx
no start on new engine s60r
Old 06-16-2019, 12:22 AM
vladniko's Avatar
Default no start on new engine s60r
So trying to help out my friend. He bought an s60r, few weeks later it had rod knock. Found a new motor and replaced it. Worked for a few days and now it doesn't start up no more. Have vida for 2 more days so ask away. Here's what we've tried.
Checking all grounds.
Flashing the clear ecu code.
Flashing the transponder reprogramming.
New ignition key ring thing.
Flashing ETM reload.
Current notices on the DIM:
CHASSIS SETTINGS SERVICE REQUIRED
BRAKE ASSIST SERVICE REQUIRED
ABS/ANTI-SKID SERVICE REQUIRED
START PREVENTED TRY AGAIN
REDUCED ENGINE PERFORMANCE
nothing.
The transponder faulty signal has been coming and going. Any help is appreciated
If you have ideas lmk! Attached are the vida readings.
porkchop112699
04-22-2021 08:01 PM
belalkamal
02-15-2020 01:17 PM
everbeenson
05-11-2019 05:44 PM
Cindy1988
07-25-2010 07:29 AM
Quick Brick
11-25-2008 04:38 PM
Quick Reply: no start on new engine s60r
