2004 S60 2.5T CHECK STOP LAMP Issue! AHHH!!!
I've tried everything with this car... then I thankfully came across volvoforums here and hopefully some of you guys can shed some light.
It's an '04 S60 2.5T
check stop lamp indicator comes on when you press the brake pedal.
The third brake light works fine, it's just the 2 side brake lights.
After some searching on here, seems like it may be a faulty relay or shunt.
I took a pic of my setup of the relays and shunts in the trunk area and it just seems like something is missing or maybe I'm testing the wrong ones.
anyway, here's the pic... am i missing any relays/shunts?
if not, which ones should i be examining?
P.S. - i realize the fuses for the brake lights are 10A, it's because that was the first thing I switched out. Old ones were 7.5A.
thanks to all who can help.
This may sound weird but I've seen a car with the bulb message and it had the wrong bulbs installed. The owner got the left bulb by taking the right one out and buying that one, however the left one was wrong so in the end he had two wrong bulbs. I know it sounds stupid but I thought I'd let you know
If it's not those, then wiring is quite likely. I found the '04 diagram and have attached it. Since your 3rd light works, then you can limit your search to the wire between the CEM and REM (The one with the 54/43 next to it) and the wiring after the relay and shunt.
If you have one a voltmeter (or one of those 12v tester lights) check for voltage, with the pedal pressed, at the fuse 11D/14 pin1. Pin 2 should have a ground (some resistance from the bulbs too.) If not, see if you can find that splice (53/667).
Let us know how it goes!
Old thread but help
Swede60
12-02-2017 09:41 AM
irieite
03-11-2016 11:21 PM
