Drive-E fuel economy
I thought I'd pass on the fuel economy results of a 1070 mile trip I took where I decided to check the indicated fuel economy against measured.
The trip consisted of about 200 miles of typical New England twisty, hilly two lane roads going through lots of small towns. I averaged about 45mph and the reading showed 34.3mpg. The rest of the trip was interstate through New York and on to Illinois where I drove between 72 and 75mph most of the way.
I also did several long checks on the odometer which showed that it underreported the distance by 0.6%.
At the end, the display showed 35.9mpg while my calculation was 35.4, a difference of less than 2% which I thought was pretty good.
In previous long trips where I just relied on the readout, I found that the V-60 is very sensitive to winds in terms of fuel economy. I did the same trip in June with a 10-15mph head/crosswind and it knocked things down to just over 30mpg.
Overall, I think that Volvo has hit a home run with this engine, especially since the new XC-90 is using a more juiced up version so it's clear Volvo is putting a lot of their eggs in the Drive-E system. Now if they could just smooth out the start/stop system which is incredibly crude compared to the Camry Hybrid we have.
I have a new V60 2015 E Drive. about 3000 miles on car. Have taken trip recently a trip lots of highway, some 2 lane road. Averaged 34 mpg. Highest seen over tank full was 35 mpg. Actually am a little disappointed since highway rating is 37 mpg. In my most recent cars (2009 Audi TT and 2005 Subaru Legacy) I have achieved 1 or MPG above the highway rating on such trips.
yes. If you go into the my volvo settings in the dashboard there is a setting that determines if the engine stop start feature is either enabled or disabled each time the engine is started. If you untick the checkbox in the dash, then the green light on the button will be off every time you start the car. In fact, whdn i picked up my 2017 s60 t5 inscription, the engine stop start feature did not work, evev though the green light in the button at the bottom of the stack was illuminated. I had to go into the my volvo settings and toggle the check box off and back on. It has worked fine since thrn.
The engine has to be running and it has to be warmed up, the outside temperature has to be between 23 and 87 degrees F, your seatbelt has to be on and you have to drive it fast enough to get the system to engage. I think that's about 15 MPH. Then navigate to the Drive-E area from the My S60 screen and select Engine System. Once you get to there, toggle the system off by pressing the green illuminated button on the bottom of the center stack. You should see a "system off" message on the screen. That's it. Since I didn't want to disable it, rather I wanted it to start working, I just toggled it off and back on again with the car idling to get it to start working. Another way to disable it is to put the gear shift into sport mode. Another area in the menu that disables it is My S60 - My S60 and put a check in the ESC off box. That puts the car in sport mode with electronic stability control off (or at least turned down a lot) to allow mild drifting, etc.
once you reach that point in the menu, at first, there is nothing on the screen. If you press the green illuminated button on the bottom of the center stack, you will see the statement appear to tell you if it is enabled or disabled. Pressing that button toggles the option off and on.
SwedishGermanCars
04-30-2005 11:09 PM
