Sponsored by:
Sponsored by: DashLynx
tail brake lights on when driving
Old 05-05-2012, 09:30 AM
sime's Avatar
Default tail brake lights on when driving
Hi guys I have problem with brake lights they came on after big rain and I managed to turn them off but now when car is on lights are on all time,brake light switch is ok and it is working when car is off, fuses are ok, REM I can not check and CEM same thing, I do not know what else to check thank you.
Old 05-05-2012, 10:23 AM
Must be the switch. Which ones are on? Post a picture.
Old 05-06-2012, 06:19 AM
sime's Avatar
left right and center brake lights,I checked switch and is working when engine is off brake lights come off and when engine is on brake lights come on
Old 05-06-2012, 08:16 AM
I meant the light switch that controls the head lights. The are on when the key is OUT of the ignition?
Old 05-07-2012, 05:18 AM
sime's Avatar
head lights are ok only brake lights are on when engine is on
sime's Avatar
and giving me message check brake lamp
Old 05-07-2012, 05:20 AM
sime's Avatar
I am thinking to go to volvo to scan CEM and REM
Old 05-07-2012, 08:30 AM
The more you write about it the more I think your rear fog is on. You need to post a picture.
The brake lights are indipendant of the car running. You can get in a car, press the brake pedal, and the brake lights will come on. Has nothing to do with the car running. If you have a brake/cruise cut off switch malfunctioning, maybe they can come on when the car is running but I doubt that.
Old 05-08-2012, 08:46 PM
sime's Avatar
tail brake lights on when driving-volvo.jpg here is picture
88740gle
11-13-2015 08:13 AM
aznyaz
01-09-2015 02:38 PM
Mellott
06-13-2011 11:41 PM
buellfire
06-20-2009 12:37 AM
marvb1
03-24-2007 05:35 PM
Quick Reply: tail brake lights on when driving
