Sponsored by:
Sponsored by: DashLynx
S60 Steering Stops Limiters swapping
Old 01-19-2017, 10:06 PM
PineTree's Avatar
Default S60 Steering Stops Limiters swapping
Got under the car today, as the tires are rubbing the wheel wells on full turns. This is what I see:
or
Volvo 2006 S60 Steering Stop Limiter wear - Album on Imgur
I read that these can be swapped from side to side, but as I look at the part(s), they seem to be longer on one bolt side than the other.
Do the rubber "bumpers" come off the metal bar, and are swapped that way, or is my particular S60 not able to have these swapped from side to side, to avoid installing new ones?
I'm running 215/55R16s, and IPD says I need these;
https://www.ipdusa.com/products/1170...limiter-17-5mm
Has anyone done this kind of swap on an '06 S60? Or do I need to order the parts new?
Old 01-20-2017, 05:55 AM
ES6T's Avatar
They can be swapped, but if they are worn, they should be replaced.
You can also shim them out with washers.
Old 01-20-2017, 08:24 AM
PineTree's Avatar
thanks!
I did order replacements, last night, but I think we'll try to do a swap. If nothing else, the bolts will get loosened up for a replacement. It's double work, but I'm lending the car to someone who would be really uncomfortable hearing that rubbing.
cannuck
1998-2000 model year V70
05-19-2013 12:07 AM
nicolaselias
03-30-2010 09:54 PM
trooperone
04-14-2009 09:53 PM
bryansofl
11-11-2007 06:38 PM
Steamroll9
05-10-2005 08:41 PM
Quick Reply: S60 Steering Stops Limiters swapping
