abs, srs, check engine, etc lites come on
Old Nov 15, 2006 | 01:27 PM
steveroe's Avatar
Default abs, srs, check engine, etc lites come on
Daily and intermittently these things are happening to my 99' S70 with 114K miles
Brake light, check engine, ABS, Flashing Arrow, STC, and the speedometer will stop working while the mileage displays -------.
Also the car will shift into the mode as if you pressed the W button for driving in snow. This is a lot of stuff happening for me to believe I could have just one faulty sensor/module, but I'm not a Volvo expert.
Front brakes are new, rear brakes are 50% worn.
I've read a lot about the ABS module breaking down and needing replaced, but would that cause all of my symptoms?
These codes come up sometime on my CHEAP scanner:
P1618 Manufacturer Contrl Auxiliary Inputs, Auxiliary Outputs
P0722 Output Speed Sensor Circuit No Signal
P1550 Manufacturer Control Vehicle Speed Idle Speed Control, Auxiliary Inputs
Anxious to hear ideas.
Old Nov 15, 2006 | 05:30 PM
Volvaman's Avatar
Default RE: abs, srs, check engine, etc lites come on
That sounds a lot like what I was experincing earlier this year. And Yes it was all related to the ABS Control module. I shipped mine out to Victor and he repaired mine. No other problems since. I did buy a code reader so that i could replace the codes once the ABS Controller came back. Autozone would not clear them for me. Let me know if you need Victor's contact info.
ST
Old Nov 15, 2006 | 09:11 PM
BAD ABS module.
Old Nov 19, 2006 | 07:06 PM
afoic2005's Avatar
I've had all the same symptoms from my '99 Volvo S70. Would love to have "Victor's" conact info if possible! I appreciate any help you could give! Thanks
Jason (afoic2005)
Old Nov 21, 2006 | 12:34 AM
volvotechky's Avatar
before you spend $$ on a ABS module, i had my bell rung by these same things, it was the battery cable in the relay box dropping voltage on start up causeing all of my probs, its a quick check and save ya some $$ i could get pics of this cable and one i found almost burned in 2,
also make sure you have a good 12v supply
Old Nov 24, 2006 | 12:34 PM
steveroe's Avatar
Low voltage/battery cable sounds like a cheap fix, and a probable cause.
The intermittent nature of ALL these problems seems to indicate something like you have named.
Can u point me in the direction of the "relay box" you are talking about?
I'm new to working on Volvo's and am still learning where everything is.
Old Jan 8, 2007 | 12:39 AM
afoic2005's Avatar
I'd love to know where the relay box/battery cable is and how to test for any drop in voltage. Been experiencing the same ABS/Speedo/Odo/Brake/TRACS lights for several months now. Before I send off the ABS module for repair/replacement, figured I'd better check out all the possibilities. I appreciate any help (especially diagrams/pictures) anybody could be! Thanks!
afoic2005
Old Jan 8, 2007 | 03:44 PM
steveroe's Avatar
I sent my ABS module to BBA Remanufacturing. Found them on E-bay motors, occasionally they run sales on the rebuilds. I expect it back on 1/10/07. Weather permitting I'll install it this weekend and see what happens. Info I read from them tells me the codes will clear with some driving. No need to re-set.
Symptoms with ABS controller disconnected: ABS/Brake/Check Engine/SRS lites are on, Speedometer and odometer do not function, Car is no longer shifting into Winter mode on its' on.
Old Jan 17, 2007 | 10:50 PM
steveroe's Avatar
Got my remanufactured ABS module installed. Speedometer is working fine, ABS lite is off, STC is off, Brake is off, and it's no longer shifting into TRACS on its' own. I still have two indicators lit. They are Check Engine and SRS.
Autozone reads codes as P0722 (no voltage at the output speed sensor), P1618 (SBDS Interactive codes), and P1633 (KAM voltage too low).
BBA manufacturing claimed the codes would clear themselves after the ABS was installed, but I've driven over 100 miles now.
Does anyone know for sure whether I need to clear the codes manually, or since I have an SRS lite, is something else wrong?
Old Jan 17, 2007 | 11:44 PM
Get the codes cleared.
Most likely they were triggered from the ABS module.
Old Jan 18, 2007 | 05:48 PM
uncle's Avatar
I've had siimilar probs on my V70 but my speedo was fine, no SRS messages and my Emissions message was there long before the ABS issues. I thought it was a bad ABS module but i took it to my auto electrician and he replaced one of the speed sensors. No ABS or DSTC messages any more and I still have the Emmissions message. I think i might be back to throttle or MAF. I beleive i have a TCM upgrade available.
Old Jan 24, 2007 | 04:12 PM
steveroe's Avatar
Yeah, I have cleared all the codes with a cheap scanner. The only light left on is the SRS. Do I need to do something else to clear it?
Old Jan 24, 2007 | 10:06 PM
Dealer or a $3000.00 scanner.
Old Jan 27, 2007 | 03:41 PM
steveroe's Avatar
I've driven about 500 miles since replacing the ABS module and have had NO problems. I did have to manually clear the codes. Car has passed state inspection and emission inspection with flying colors. Still have SRS lite on and the dealer wants $50.00 to check it out. They won't budge. Thanks to all for the advice on the ABS.
Old Jan 27, 2007 | 03:47 PM
Glad all is good now.
Check a Volvo Indipendant specialists if you have one in your area for the SRS.
Old Jun 27, 2007 | 09:38 PM
mjoyner's Avatar
I have just experiecned the same problems in my volvo 1999 s70. could i get that guys info to repair the part. the Deal want 865 for the part. but he called it a Sensor Module.
Danigirl
Feb 22, 2012 01:36 PM
zloetakoe
May 28, 2011 07:29 PM
buckeyecal
Jun 24, 2010 04:23 PM
acorales
Mar 26, 2008 09:46 AM
afbere
Oct 5, 2005 01:40 AM
