tyre pressure
Old 09-10-2007, 05:25 PM
ocean238's Avatar
Default tyre pressure
what tyre pressure is everyone set to on the stock alloy with 195/60R15 88V?
I was on
32psi- front
back i had them on 32pis but the petrol cap says they should be on:
32 - front
29 - front driver
36 - back
is that a bit too high?? 36psi at the back?
so i was just wondering what everyone has their's on
thanks
Old 09-10-2007, 08:32 PM
01_fast_ride's Avatar
Default RE: tyre pressure
I have all 4 of my tires set to 40psi for better gas mileage. I don't drive super fast so uneven tirewear isn't an issue as much. The max sidewall pressure is safe unless your tires are showing alot of wear. Mine say max 44 but I stay a bit lower because they're showing some signs of age. I know a few others here are running high tire pressure as well, but its a known fact that higher pressure equals better mileage.
Old 09-11-2007, 08:39 AM
S70driver's Avatar
Mine are all set to the same tire pressure. Which is like 38 PSI.
Old 09-11-2007, 03:14 PM
ocean238's Avatar
right maybe i should try having them all on 36psi and see what happens.
never realised everyone set their tyres so high, i used to leave them at 30psi and soon realised it;s not ideal
Thanks everyone keep posting so i could try out different ideas!
Old 09-15-2007, 07:56 AM
Just so you don't worry, higher pressure in your tires will give you a firmer, harsher suspention feel, but it's normal.
Old 09-17-2007, 04:50 PM
ocean238's Avatar
i drove about 100 miles on the motorway today with the tyres at 38psi, noticed the difference in the car's handling, it seems to be swinging heapsmore, is that normal? should i set the back to lower pressure?
Old 09-19-2007, 02:20 PM
That's exactly what i'm running, 38 all around. I don't see no problem to lower it back if you stay within specs.
Just note that the higher the pressure, the better the fuel economy and the firmer will be the suspension. Tires absorb a lot of the bumps... Make shure you don't go over the max pressure written on your tire wall.
Old 09-21-2007, 06:24 PM
ocean238's Avatar
nah, i m keeping them on 38, altho I really did notice the difference with the handling, but, fuel economy will save me money whereas good handling won't!
Old 09-23-2007, 10:30 PM
I used to have my tire pressure at 35psi until last week. I changed it to 40psi front and rear, under the 44 that the BFGoodrich tires state as max, and noticed quite an increase in fuel mileage. The ride wasn't too noticeably rough compared to the previous pressure.
Old 09-24-2007, 06:22 AM
ocean238's Avatar
hey sixdown
how much are you getting in terms of fuel mileage? I have set mine from 32 to 38 and noticed one tank of full petrol now would do about 360 miles instead of 310 miles before the warning light comes on, i m debating if i should put them on 40psi again...
Old 09-29-2007, 06:19 PM
well, I noticed that im getting around 350 miles per tank, but that depends on your driving habits.
Old 02-03-2008, 02:28 PM
Quick Brick's Avatar
Hey now,
I have, probally because of bad habits[sm=nono.gif] picked up over the years, thought that 32-35psi was the norm and that anything higher was a bad idea due to preasure increasing when driving and I was always concerned about reaching the max preasure and having problems with poor wear.
But by reading the postings here a range of 35-40psi would seem to be better even if the ride is a little more firm.
I have just had a serious amount of work done to the car, including new suspension, brakes and winter tires which haven't seen any snow due to the car being in the shop since last Nov, [sm=headbang.gif] don't ask, and I'm waitingfor the starter replacement(Feb. 04-08) and will check the preasures to see where they are and adjust accordingly.
I'll post the total fuel economy/milage after the second full tank is used to get a fair idea as to whether or not my milage is better. I was getting better than 630km per tank before the exhaust gasket failure [sm=smiley20.gif], 450km after[sm=smiley21.gif] and then the water pump bearing failure[sm=outcold.gif] which is why the car has been in the shop. Replacement engines aren't cheap or easy to find with low km's.
[sm=icon_cheers.gif]and [sm=icon_rock.gif]
Old 02-03-2008, 05:42 PM
I run all mine at 36 PSI.
bitnissen
09-21-2009 01:06 PM
JPN
02-17-2007 07:02 PM
chin
12-05-2005 01:15 PM
matty052
03-19-2005 12:12 PM
matty052
03-18-2005 10:35 AM
Quick Reply: tyre pressure
