Engine light and winter/low gear light arrow flashing
Old 09-09-2005, 01:34 PM
Volvaman's Avatar
Default Engine light and winter/low gear light arrow flashing
Hi all,
I was driving on my way back from Chicago (to Cincinnati) last night and the engine light came on as did the flashing low gear winter light/arrow. I was about 200 miles from cincy, fortunately I made it home. Also didn't notice any difference in performance This tells me it is probably a sensor or else my butt would be stranded on I65. The mass air flow sensor was replaced in June of this year. I haven't had a chance to take it to Autozone to run the codes. Just wnated to know if anyone has encountered this problem before? I will take it to Autozone and post the results later.
Update on the the dreaded Electronic Throttle body. About three weeks ago I took my car in to the dealership for the 75,000 mile service and because i felt hesitation or loss momentary power when driving the car especially on the highway. They ran diagnostics and it came back as a faulty electronic throttle module, i gues due to clogged vacuum nipple. They supposedly replaced with a new style ETM. I wasn't aware that there was a new style. I had heard that volvo was replacing the ETM with same throttle module albeit new.
Old 09-09-2005, 07:00 PM
Volvaman's Avatar
Default RE: Engine light and winter/low gear light arrow flashing
Hi all,
I had a chance to take the car to Autozone and the following codes were present. p1618 - manufactures control -- input and out --- P0711 - Trans sensor. Any idea what these do and how hard they are to fix?
Thanks
Old 09-09-2005, 07:11 PM
alecw81's Avatar
I'm going to guess that's a sensor in the transmission or the shifter that thinks the car is in winter mode. I'm sure Tech will have a more informed response.
Old 09-09-2005, 08:18 PM
Volvaman's Avatar
Thanks for the reply Alec 81. I can still shift into and from winter mode.
Old 09-09-2005, 08:47 PM
Yes it might be a bad PNP switch.That is the main switch on the transmission that tells the comuter what gear it is in and other things like that.
Old 09-10-2005, 01:08 PM
Volvaman's Avatar
Tech how hard would the trans sensor be to replace and alaso what about the manufacturers controll. Any idea whatthe manufactures controll does?
Old 09-10-2005, 01:59 PM
Im not sure about that code.I know Volvo codes not the aftermarket codes.All of our scanners at work use Volvo codes.
The PNP switch is not really all that hard to replace.You will have to remove the battery tray to get to it properly.
Nathan007
10-02-2014 06:32 PM
Henry Jones Junior
06-04-2012 02:30 PM
volvobrain
02-04-2011 01:05 PM
Georgia Boy
04-11-2010 01:13 PM
Silencer1
02-16-2010 08:22 PM
Quick Reply: Engine light and winter/low gear light arrow flashing
