2005 S80 Trunk lock cylinder - replacement? key worn't go in
Old 10-28-2016, 02:19 PM
gvsu4msu's Avatar
Default 2005 S80 Trunk lock cylinder - replacement? key worn't go in
Hello all,
recently the trunk lock cylinder stopped accepting the key. Key can only engage part way.
I have been using the key as the remote does not open the trunk. I am not sure if it is the remote or the little black "button" on the trunk that is not working, or if it is user error.
So I a need a way to be able to enter the trunk, and not always have to have my backseats folded down (or sending my child in the ski hole to pull the (US) escape lever. Thus I have a few questions.
Can this lock cylinder be replaced?
Is it as simple as removing the two nuts holding it in from the inside?
Where can I get replacement one?
Do I need to get a new key to use the lock?
Old 10-28-2016, 09:21 PM
thommykent's Avatar
Originally Posted by gvsu4msu
Hello all,
Probably the relay for the black "button". Easy to check once you get the trunk open. Just swap a relay from the fuse panel inside the trunk. If a relay swap does not work then it`s the "button"
Yes
Yes
Dealer, junk yard or ebay
A locksmith can re-key the cylinder to use your current key
Re4ty3
07-29-2016 04:14 PM
guest01
04-04-2014 12:20 PM
matchs
11-19-2013 10:23 AM
timalabim
11-27-2008 02:01 AM
shrinehart
05-16-2008 05:53 PM
Quick Reply: 2005 S80 Trunk lock cylinder - replacement? key worn't go in
