Cost estimate for valve job after timing belt slip
Old 03-21-2008, 01:09 AM
nicolaselias's Avatar
Default RE: Cost estimate for valve job after timing belt slip
The tensioner pulley i believe it is that im missing....
Where would you say is the cheapest place to get the parts for the job?
Thanks
  #42
Old 03-21-2008, 06:21 PM
Sounded like you had it covered in the post already.
There is 2 pulleys and the belt.
Tensioner,Idler, Did you check e-bay?
  #43
Old 03-22-2008, 02:13 AM
I did actually, saw the continetal kit selling for about 140... which looks to be the same as eeuroparts.com
how does this look, is it everything i need for the job?
http://cgi.ebay.com/ebaymotors/2000-...spagenameZWDVW
thanks
  #44
Old 03-22-2008, 02:22 AM
Oh tech, also.. how much will the t belt + serp belt job be up at the shop where you work?
i talked to my mechanic here in tampa and he said hes not sure if he wants to take on that job, he said its just too much trouble and time consuming, as he did it in a v70 and he said it took way longer than planned
  #45
Old 03-22-2008, 07:57 AM
Yes that is what you need.
I can't believe that he doesn't want to do the job!!!!!
I would have to check from work to see what just the labor would be.
If all else fails I will do it home for about $200.00.
  #46
Old 03-22-2008, 02:36 PM
Thanks tech... il order the parts and see how its going from there...
hopefully I can just get all the work i need done at once...
is there any particular brand that you reccomend for the timing belt? Im seeing continental, gates, ac delco etc
thanks
  #47
Old 03-22-2008, 02:52 PM
if you dont mind me asking, whats the difference between these 2 timing belt kits...
both say they are for 02 s80 2.9l's
vs
the second one is 50 dollars more but it is
**This kit if for use with Hydraulic Tensioner Systems** NOT FOR MECHANICAL TIMING BELT SYSTEMS
Thing is im not really sure if i have a hydraulic tensioner system, i assume i dont but just looking to make sure...
thanks
  #48
Old 03-22-2008, 04:58 PM
Your car has a mechanical tensioner.
Get a Continental belt that is the OEM belt best in my opinion.
Only some 1999's have a hydrolic tensioner.
  #49
Old 03-22-2008, 10:17 PM
Thanks tech.. il make a point of getting the conti... eeuroparts has all the parts totaling 140 with free shipping and they have servedme well in the past... il try to get a conti s-belt also...
il let you know how if i can come to the shop, if not im sure we canjust do itby you if thats fine with you..
thanks
  #50
Old 03-22-2008, 10:23 PM
At the house is fine right now actually better for me.
  #51
Old 03-25-2008, 03:10 AM
Parts ordered, should have everything here by the end of the week. The s-belt, t-belt, tensioner and idler totaled 170....
Whenever is good for you we can get this done, il feel at lot more relaxed knowing i had the new t belt in there..
  #52
Old 03-26-2008, 06:37 PM
The next couple of weekends are bad for me Inlaws are here.
  #53
Old 03-26-2008, 11:40 PM
To be honest tech, same deal on my end, very very busy weekends...
I dont really plan to be doing much driving between now and the end of the april, right after that I may have to make a run to miami and quite a bit of driving around tampa though so I guess once it could be done sometime before then..
I still have the oil leak worry but I guess thats a secondary problem, once i keep enough oil in the car I should be fine for the while..
just let me know how your schedule is looking and I guess we will just change the spark plugs while were at it...
  #54
Old 04-01-2008, 01:33 PM
Hi tech, visited the mechanic today and hes quoting me near 600 for the job (T belt, idler, tensioner, s-belt and he claims i have a leaking valve cover gasket)... sounds like quite a bit so if possible, il prefer to do the job by you. How much is the valve cover gasket and how much extra labour would it be to change? Is it a big job?
Let me know how its looking...
PS. If we are doing the work, any chance we can do the spark plugs, fuel filter, and upper torque arm bushing while we are at it?
Thanks again tech, keep me post
  #55
Old 04-01-2008, 08:09 PM
I will want to see it myself for the leaks.
The Valve cover(Really called cam cover) very very rarely ever leaks. It is a really big job like I thikn 5 to 6 hours or so.
Maybe just the seals are leaking but I want to see it myself.
We will have to meet up soon.
  #56
Old 04-01-2008, 08:44 PM
Its no problem tech.. whenever is good for you, either on fridays or on the weekend I can work with....
This new mechanic has a pretty popular place near the univ, alot of professors go to him and so on so hes well respected around the area, I trust the guy, i would just prefer a volvo specialists opinion on it..
I have all the t belt parts already and UPS was supposed to deliver the S belt today but in typical fashion showed up to my place after 6pm.. so i wasnt home
  #57
Old 04-01-2008, 08:52 PM
Oh ok we will talk soon about doing it.
  #58
Old 04-02-2008, 06:15 AM
you should be able to get all 4 of those parts replaced for less than 600. i took it to a volvo dealer and they did it for 300 even.
  #59
Old 04-02-2008, 12:53 PM
Thats my point, i just needed him to take a diagnostic look at things but i have no intention of doing the work at his place....
Im still thinking about the rear crankshaft seal, thinking if maybe i put the wrong oil, or i should have been using the high mileage oil all along etc... i think its just bad luck but i keep looking for a way to blame myself...
Anyway, i know the job shouldnt be over 300 so im wondering what hes on about... maybe because of the cam cover the price went up to 600?
isnt $95 an hour labour pretty steep for someone who isnt a volvo specialist? He says thats his rate for volvo but im sure there are independent volvo shops cheaper than that
  #60
Old 04-03-2008, 02:48 AM
Finally got my s belt, UPS delivered at 830pm..
So, im ready for the job, whenever you are free tech, just let me know.
Thanks again,
Nicolas
PS. If you go onto http://www.gocontitech.com/ , you can get a free t shirt just my filling out their 1 minute survey...
Quick Reply: Cost estimate for valve job after timing belt slip
