The update ways of autel maxidas ds708
Old 03-27-2012, 03:48 AM
light8008's Avatar
Default The update ways of autel maxidas ds708
First is data logging, the data logging function is used to report the problem that cannot be detected or solved by the maxidas ds708. To perform a data logging, follow the instruction below to operate the data logging while the vehicle is being scan. The error report will be sent to the technical support center automatically. The engineer will try to solve the problem and get back to you within 48 hours with the update function. You can finally upgrade your maxidas ds708.
Note: The following picture shows the process of the data logging.
Old 08-21-2012, 02:15 PM
ishy62's Avatar
I just want to be sure I understand. If the Autel maxiDAS DS708 can't detect or solve a problem with vehicle, I can use the data logging function to send information about the problem to an engineer? From there the engineer should be able to provide an update to the MaxiDAS DS708 to add support for the problem? Seems like some sweet tech support if so! Is 48 hrs guaranteed? That would be impressive
Old 08-21-2012, 05:54 PM
akabond's Avatar
damnn thats expensive
Old 08-28-2012, 03:00 PM
ishy62's Avatar
Seriously... Not for your hobbyist, but maybe your mechanic
Old 05-28-2013, 01:34 AM
Jack Chen's Avatar
Hello,
I'm interested in your Maxidas DS708 Diagnostic unit. Regarding this unit:-
1. Please can you tell me if it is a genuine english language, UK designated model?
2. Is it updatable, how many updates come with it, and does it 'time out' if not updated?
3. Who/where do i turn to in the event of a warranty/guarentee claim or return?
Thank you in advance,
Old 02-24-2017, 10:58 AM
jenkinskg's Avatar
Just got a md802, does a lot on my 3 volvos
tankhokie
01-09-2013 11:41 AM
The Viper
04-03-2012 05:31 AM
kejeon
07-17-2010 12:23 AM
SuperS40
02-01-2009 09:40 PM
Jonathan Logan
08-18-2008 05:54 AM
Quick Reply: The update ways of autel maxidas ds708
