Check engine light, trans mal light, W/S/E/ light flashing
Old 06-19-2008, 06:15 PM
ErnstlS90's Avatar
Default Check engine light, trans mal light, W/S/E/ light flashing
My mother has a 1998 S90 that has the check engine light on and intermittantly the transmission malfunction light flashes with the W/S/E light in the shifterflashing alternately. The check engine light is throwing a code for the speed sensor. So far the speed sensor, transmission shift selector and ignition switch have been replaced. The problems came back a few weeks later with the check engine light staying on and the other lights only flashing intermittantly which has always been the case. Does anybody have any clues?
Old 06-20-2008, 06:49 PM
Default RE: Check engine light, trans mal light, W/S/E/ light flashing
Same exact problems here, except for the speed sensor mention. I don't know why my check engine light is on but I have had the same intermittent problem with the transmission warning lights and the WSE lights flashing. However, the transmission faults go off and do not particularly seem to indicate be serious. I've also seen my radio warning light come on right after starting and then shortly thereafter turn off. Check the fluid levels and looks fine. [shrug]
How did you get the speed sensor code? Do you have an OBD II reader? I was tempted to buy a cable/software just to figure out what is going on with the check engine light.
T
Old 06-20-2008, 06:53 PM
ErnstlS90's Avatar
I had a friend of mine that is a Jaguar technician pull the codes.
Old 06-21-2008, 06:43 PM
The PNP switch might be bad.
Old 10-23-2008, 08:37 AM
960 rookie's Avatar
Tech is right...I have a known issue with my PNP switch, and it WILL exibit the flashing arrow and W/S/E lights from time to time. My transmission is fine, switch is going. So, it COULD be your switch.
Nathan007
10-02-2014 06:32 PM
Silencer1
02-16-2010 08:22 PM
Knac21
08-08-2009 12:00 AM
BRB
02-09-2008 12:29 AM
Wifeys1998XC70
09-21-2007 06:08 PM
Quick Reply: Check engine light, trans mal light, W/S/E/ light flashing
