Ignition Control Module Location
Old 10-15-2016, 04:28 PM
Haggis_Warrior's Avatar
Default Ignition Control Module Location
I have a 1997 S90 on which I am trying to replace the ignition control module(s) I think they are failing. I am having a hard time locating them under the hood. Does anyone know where they are located or have any ideas where to look?
Thank you.
Old 10-15-2016, 06:31 PM
Smith Volvo's Avatar
Banned
Thank you.
buried on the drivers side right next to the left hand motor mount - and yes - there are 2. Make sure you check the black ground wires while you are at it - common for these to work loose at the grounding screw and loose spark also. More likely these are the culprit instead of the modules in fact.
Old 10-18-2016, 01:40 PM
Thank you so much for the reply. Hopefully I can find them now. I will check the ground wires as well. Once again thank you. 😃
one to remember
04-20-2016 01:29 AM
dcman411
01-15-2015 09:43 AM
Volvo bro
02-09-2013 07:28 PM
I am Phil
01-26-2012 08:20 PM
mikes940
04-23-2010 10:08 AM
Quick Reply: Ignition Control Module Location
