Loud Squeal/whine
Old Feb 13, 2010 | 12:30 PM
ced's Avatar
ced
Default Loud Squeal/whine
my 2001 V70 develops a head-turning loud whine after about 45 minutes of driving. I have invested in a new timing belt, pulley, water pump, serpentine belt,power steering fluid flush and refill...nothing has solved the problem. When it is at it's loudest, there is a fluctuation in idle rpm. also noticed if I put it in neutral and rev engine it goes away until I start driving again. Any ideas?
Old Feb 13, 2010 | 01:50 PM
malaka's Avatar
You might need to "invest" in a mechanic's stethoscope..... a section of garden hose about 2 feet long. Alternator, power steering pump can be isolated to hear if that's the source of the noise. Maybe you can isolate it without using the hose, but those two items might be getting too hot, suffer failing bearings, or in the case of the alternator, overload. I'd start with these.
Or, one of the new parts is misaligned, not properly tightened, or slipping.
The stethoscope will help isolate the noise source if its at these locations, too.
I'm suggesting this because its cheap. Besides, I use mine to fill my power washer with RV antifreeze in the fall so the pump housing won't freeze and crack.
Old Feb 13, 2010 | 03:55 PM
ced's Avatar
ced
Thanks - yeah, my biggest concern is I wasted the 900 and they didnt do the job right. Mechanic was absoluely positive it was the pulley he replaced.
Tim Garvie-Maclean
1998-2000 model year V70
Oct 13, 2014 02:45 AM
sjv13
Apr 21, 2011 06:47 AM
sethgoodwin
May 1, 2009 09:00 PM
VinUnleaded
Dec 29, 2005 01:37 PM
rmclemns
Aug 25, 2005 09:15 PM
