Drive Shaft rebuild, anyone done one?
I have a 98' AWD with a bad drive shaft, it is the front joint. I have decided to order the replacement joint from the dealer, looking for someone who has done it before who can give some tips or if they know there is a write up somewhere. I searched and did not find anything. It is the 95mm version if that helps at all.Thank you in advance for your help.
RE: Drive Shaft rebuild, anyone done one?
See if this works. Here is a picture of the rebuild kit.
Alright I cannot get the picture in the post, here is a link to what it is.
http://www.fcpgroton.com/product-exe...ategory_id/103
I went to FCP Groton to look for it, I can not say that type looks like others I have done.
Having said that, FWIW, I would begin by removing the outter bolts holding it to the flange. It looks like once you drop the shaft you will find a dust cap held in place by the externally expanding spring (works like an internal circlip). To remove it, just pry the end out with a small screw driver. Once yo uhave the cap off you will see a nut on the inside. It will more then likely been peened into a grove in the shaft. This nut is what retains the joint onto the splines of the shaft.
I would recommend you have access to an air impact wrench to remove this nut, since it will be tough to hold the shaft firmly enough to remove the nut.... I would NOT recommend putting the shaft in a vice since it is likely hollow and even a small dent will put it out of balance.
Once you have the nut off a few taps should remove the joint from the shaft. You should be able to replace the parts in the reverse order that you removed them, if you can not find a torque spec for the nut then post the diameter of the shaft and I will look for a SAE spec of the nut by size.
Hope this helps.
Hope this helps.
I'm buying the rebuilt axles off eBay and having someone do it for me. For my 01, they run about $110 to $120. My CV boots are in bad shape so I started looking at rebuilt axles.
For your model V70, you can find the entire axle, driver and pass. on there. Many people suggest it's better to just replace the entire axle with a rebuilt one then try to buy parts for it because it ends up being less time and less expensive.
That's just what I hear though.
I believe he is talking about the drive shaft to the rear, not the CV axles. I know they call the CV axles 'drive shafts' in the UK so I could be wrong, but the joint he posted is not for a front axle.
FWIW, FCP Groton has the CV axles for $75 each. I read that they had some quality problems with these axles in the past, but I just installed a set... I will keep everyone posted as to my findings.
Thanks for the response. This is for the drive shaft that connects the front transmission to the rear differential. The part should be here this afternoon of they can make it thrrough the 3 feet of snow that fell last night.
I do have air tools so that will help. I am fairly mechanically minded so I should be OK. I was hoping someone else had done this but it soinds like no. I will post how it went tomorrow or tonight.
I actually am working on a new shaft that uses more standard joints but it is taking to long for the math on how it will spin at speed with added weight and how the central bearing will hold up to that. With the snow I just could not wait anymore.
Thanks for all the replies and help.
MoneypitC70
2001-2013 model year XC70
10-26-2014 08:37 PM
Volvo-Profess
01-14-2011 05:55 PM
axle, drive, driveshaft, kit, nut, rebuild, rebuilders, rebuilt, remanufactured, shaft, shafts, size, v40, v70, volvo
