01 T5 intake question.
Old Oct 11, 2008 | 07:18 PM
greenteagod's Avatar
Default 01 T5 intake question.
Is there supposed to be a hose that comes off the bottom part of the filter box? Mine has an opening with four spots that it looks like a hose would clip into, but no hose to be found in searching the interwebs. I looked under the car and also found what might look like the other end of where a hose would connect to the front splash guard/air damn thing. I was considering procuring some flexible tubing and running it down there or seeing how fancy I could get with some PVC, but if there's a stock option that works splendidly I'd definitely rather go with that.
Old Oct 11, 2008 | 10:24 PM
TIPSP's Avatar
Got Boost?
Default RE: 01 T5 intake question.
Yeah, on our 07 V70R it has that same cap in the box. Not sure why it is there either, butI have seen some people put a pipe there to the front to bring in more cold air(well what is out side). It would be a fun thing to do, and fairly easy. IPD sellsa kitfor the "R", but its like $80. You could do it your self for like $10.
Old Oct 11, 2008 | 10:55 PM
Yeah, I was figuring that was probably the case. I wish I had the foglights like on the R so I could use that type of setup, but I think right there behind the front bumper, should be high enough pressure to get the same effect.
Old Oct 12, 2008 | 06:34 AM
http://www.canadianautoreview.com/v70-engine-680.jpg
Not my car or my pic found on the web.
But if you look in the pic just past the intercooler pipe you will see where the hose comes up to just above the radiator. It has one that goes from the bottom half of the air box up to the top of the radiator.
Old Oct 12, 2008 | 11:18 AM
Ah ha. Well bugger all but mine is entirely gone =D
Looks like it's junkyard hoppin time. I can't imaging sucking that toasty hot engine bay air is such a great thing for economy or power.
Old Dec 18, 2008 | 04:59 PM
Just thought I'd follow up on this one since I've replaced it. There are two parts to it and combined from the local dealer they were $46. The junk yards didn't have any and they said if they did it would be $75 just for the large part alone.
Old Dec 18, 2008 | 05:07 PM
Glad it is all good now.
Thanks for following up!!!
Jeff Kong
1998-2000 model year V70
May 18, 2012 05:38 PM
Stefan1235
May 21, 2011 09:00 PM
rquinonez32
Sep 30, 2008 02:08 PM
JBVolvo
Apr 6, 2007 10:17 PM
chs68
Intake, Headers and Exhaust
31
Feb 28, 2006 06:18 PM
