Where is it? Oil pressure sensor location.
Old 10-04-2004, 02:51 PM
jdnas's Avatar
Default Where is it? Oil pressure sensor location.
Could anyone tell me where it is loaceted. 2001 v70 2.4t.
BTW. THe car is for sale. 55K miles.
Old 10-04-2004, 09:44 PM
Default RE: Where is it? Oil pressure sensor location.
The oil pressure sensor is located on the front of the engine about in the middle of the engine it has 1 wire going to it.Is there a special reason you are asking? Is the oil light on?If it is it is most likely not the sensor that is bad the car has low oil pressure.There are o-rings that go bad between the oil pan and the engine.They will need to be replaced.
Old 10-05-2004, 04:02 AM
jdnas's Avatar
Yes... The low oil preasure is on. I was thinking it's the sensor so I bought one. Do I have to remove the oil pan? What O ring is it? Any picture?
Thank you so much for the help.
Old 10-05-2004, 10:40 PM
To replace the o-rings yes you have to remove the oil pan.I will work on trying to get you some pictures.You will have to replace about 4 to 5 o-rings.You will also need some special gasket sealer that you will need to buy from Volvo.
MntnDewMan
04-03-2024 04:05 PM
bydand
2001-2013 model year XC70
46
10-23-2018 11:11 PM
brettboze
03-26-2012 06:25 PM
ibified
03-04-2012 12:23 AM
sabydady
07-07-2009 04:58 PM
Quick Reply: Where is it? Oil pressure sensor location.
