Power Window Switch Auto Feature Stopped Working
Old Mar 3, 2016 | 06:49 AM
terryd4's Avatar
Default Power Window Switch Auto Feature Stopped Working
My 2012 XC60 on the drivers door power window switch three of the four power window switches "auto" feature stopped working, you can raise and lower the windows just the "auto" feature doesn't work, the only switch that works is the passenger side front door the "auto" feature works fine for that door. This started after the battery drained when I was using the ignition II, I jumped the vehicle not sure if this had anything to do with it may be coincidential.Is this a dealer service repair or is there any special trick that I can do to fix? Thanks, any help is greatly appreciated.
Old Mar 6, 2016 | 10:04 AM
terryd4's Avatar
Smile
Just a follow-up, the power window switch auto feature started working again, not sure what I did, but it started working again.
Old Sep 5, 2016 | 07:24 AM
banjo player's Avatar
My auto up & down isn't working on any window. The car sat for a month and the battery went dead. I charged the battery and all seems good but the auto up & down function. Anyone have any ideas?
Old Oct 17, 2016 | 12:53 PM
Shelby Price's Avatar
Exact same thing happened to my wife's xc60. We aren't sure what fixed it. It just randomly started working again.
Old Mar 3, 2017 | 07:16 AM
JBxc60's Avatar
Hold the button down and let the window down all the way. Then hold it to go all the way back up. That should solve the problem. Mine did the same thing and that was what the mechanic suggested and it worked.
Old Sep 29, 2019 | 04:41 AM
09MY10VolvoXC60's Avatar
I just figured it out. This is correct but additionally you have to hold in in the down and up position for at least 1 second after it reaches the end and then release the button. It will then reinstate the automatic function. You need to do it for each window.
This happened to me after a flat battery.
The internal light that automatically comes on when I remove the key fob stopped working as well. It is now working again and I'm not sure what I did to make that happen. If anyone knows maybe they can add it to this thread as they both might happen regularly together after a flat battery.
Last edited by 09MY10VolvoXC60; Sep 29, 2019 at 04:42 AM. Reason: To make it more correct
Old Oct 11, 2021 | 11:51 PM
marc3258's Avatar
It actually works. Thank you guys. I just changed my battery today & experienced the same issue: the window cannot up-down automatically. I just follow your instruction which down and up position for at least 1 second after it reached the end and then release the button. You can hear extra sound. Then it means the set up complete. You gotta do this for each window. Hope this post helps every Volvo driver after they changed their batteries.
Old Oct 31, 2023 | 03:08 PM
Gillito's Avatar
On my wife's 2008 S60, the automatic window is Not working properly, when the window goes up it doesn't stay closed, it reopens the window unless you hold the button on the up position..
I tried holding the button on the up position as suggested but unfortunately didn't work..
Any suggestions? Thanks in advance!
MissLynn
2001-2013 model year V70
Jun 9, 2017 02:34 PM
H-Bomb
Mar 26, 2013 01:05 AM
Redspringwheat
Dec 13, 2011 02:30 AM
egibson9
Apr 14, 2010 11:56 PM
rpknodel
Jan 7, 2009 11:42 AM
