2006 Volvo XC70 Bi-Xenon bulb Replacement - Need help: How?
Old 10-02-2009, 09:42 AM
TrusWeld's Avatar
Question 2006 Volvo XC70 Bi-Xenon bulb Replacement - Need help: How?
I have a 2006 volvo XC70 and I have a Low Beam Bulb Failure on my message alerts. Accordingly, my right(passenger) headlight is burnt out. I purchased a new 35W D2R bulb and attempted to change it last night. No Luck - There must be a special procedure or trick. Does anyon have some advice on how I might proceed? Do I have to remove the headlight assembly?
Old 04-27-2010, 07:05 PM
fprintf's Avatar
Did you ever find an answer to this one? I have the same bulb burnt out and cannot for the life of me figure out how to get the old bulb out... well, I did get the old bulb out but it broke in the process, and I definitely don't want to risk breaking a $130 bulb putting it in!
Old 04-28-2010, 02:41 PM
TrusWeld's Avatar
Default 2006 Volvo XC70 Bi-Xenon bulb Replacement - How to!
Yes, I did fine a solution. The following link explains with pics how to disassemble the front end to access the bulb:
http://www.volvoxc.com/resources/how...V70XC_2000.pdf
Old 04-28-2010, 07:05 PM
fprintf's Avatar
Wow, that is a ton of work! I actually got a reply from Art on the other board showing the instructions, and worked out how to do it without taking the front end apart:
http://www.volvoxc.com/forums/showthread.php?t=16212
Thanks for the reply!
fprintf
sdl92
11-02-2012 01:21 PM
gsonn
03-05-2012 01:36 AM
edcxc70
12-29-2010 02:18 PM
CarlosIV
01-06-2009 08:00 PM
ItzHerz
12-11-2008 02:24 PM
Quick Reply: 2006 Volvo XC70 Bi-Xenon bulb Replacement - Need help: How?
