Sponsored by:
Sponsored by:
Spark Plug Replacement 2005 XC90
Old 07-10-2009, 01:38 PM
JSP's Avatar
JSP
JSP is offline
Default Spark Plug Replacement 2005 XC90
Looking for instructions on replacing the spark plugs in my 2005 XC90 T6. Thanks for the help!
Old 07-19-2009, 04:39 PM
m1964's Avatar
remove plastic hoses for T-charger, air cleaner, charge air cooler.
plug the holes
remove upper camshaft belt cover,
ignition coils covers
ignition coil connectors
monting screws
pull up the ign. coils
remove sprk plugs
Old 02-22-2013, 09:33 PM
majorcode's Avatar
Can I use two sided spark plug instead of Single sided one? Please suggest.
Thanks
Old 09-05-2013, 01:36 PM
CaliVolvo's Avatar
How-to Video - changing xc90 2.5T spark plugs:
The previous video is long and you will need to forward through much of the chatter, but its helpful.
The following video is a lot shorter, and straight to point, but it's for changing the Ignition Coils which is 95% the same process as changing the spark plugs:
Also, the previous video doesn't have you remove the Turbo air pipe, but just to loosen it, which appears to work good and saves some time.
cactus13
02-04-2024 09:19 AM
futbolfan15
04-02-2010 09:56 PM
NJFordBoy
09-30-2009 08:36 AM
jimboy
04-28-2009 11:47 PM
Quick Reply: Spark Plug Replacement 2005 XC90
