Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
What is the tire width recommended for this wheel from an 850 Turbo?
Old 10-05-2016, 05:10 PM
Luke Woessner's Avatar
Exclamation What is the tire width recommended for this wheel from an 850 Turbo?
https://volvoforums.com/forum/attach...1&d=1475705344
I'm upgrading from my heavily worn steel wheels and these are cheap. What tire would you recommend?
-Thanks!
Attached Thumbnails What is the tire width recommended for this wheel from an 850 Turbo?-wheelman.jpg
Old 10-06-2016, 05:50 PM
bmdubya1198's Avatar
If they are 16"x6.5" like the newer Perfos, the factory tire size is 225/55R16, I believe. Those should work quite well.
Old 12-07-2016, 03:37 PM
OEMs should be 16 x 6.5 with a 43 ET (offset) stamp. Factory tire for the 850 Turbos with the Columba's was 205/50-16 (the standard Cetus 15 inch rims came with 195/60-15s). You can also go with a 215/50-16 if they are easier to find.
ITS ME DAVID
09-12-2009 09:30 AM
rich nc
03-19-2009 05:26 PM
gl1970
08-28-2007 02:40 PM
nightlog
06-24-2007 08:33 AM
ThE B MaN
01-09-2006 03:05 AM
Quick Reply: What is the tire width recommended for this wheel from an 850 Turbo?
