1998 V70R Aftermarket catalytic converter
Old Dec 17, 2020 | 09:23 PM
MKF13's Avatar
Default 1998 V70R Aftermarket catalytic converter
Looking for any information about putting a high flow catalytic converter on my V70R.
-Will it set any codes?
-Does the O2 sensor need to be in the Cat or after?
Old Dec 18, 2020 | 04:37 PM
older cars used an O2 sensor ahead of the cat, newer cars have a sensor ahead of the cat and another after. The sensor ahead of the cat is the lambda sensor which controls fuel trim, the sensor after the cat just measures the efffectiveness of the cat. Your replacement cat should be appropriate to your model/year. Usually cars that set codes is due to the rear sensor. The usual trick is to insert a CELboss spacer on the rear to move it away from the exhaust stream.
madisonswift
Jan 27, 2015 08:58 AM
mnmk
2001-2013 model year V70
Jan 15, 2013 10:21 AM
2003volvov70
Dec 7, 2012 10:30 AM
kirkeby
Apr 25, 2008 01:07 AM
jcleveque
Feb 5, 2008 06:32 PM
