'99 V70: Code Readings
V70 LiteTurbo @210K miles
Running 'rough': P0305 ":Cyclinder: 5 Misfire detected Do the following codes cause P0305? P1550: Charge Pressure Deviation P0722: OUtput speed sensor circuit: no signal Thanks much! Doug |
P0305s usually point to a plug or a coilpack. First I'd drop in new plugs (OEM/copper cores are best, then I'd swap coils - ie move the #5 pack to #3 and see if you suddenly get P0303 codes... If your coils have 100K or more on them are probably starting to fail where the spark is not hot enough under load.
Originally Posted by mt6127
(Post 429329)
