'99 V70: Code Readings
Old Mar 31, 2016 | 11:18 AM
osage's Avatar
Default '99 V70: Code Readings
V70 LiteTurbo @210K miles
Running 'rough': P0305 ":Cyclinder: 5 Misfire detected
Do the following codes cause P0305?
P1550: Charge Pressure Deviation
P0722: OUtput speed sensor circuit: no signal
Thanks much!
Doug
Old Mar 31, 2016 | 12:47 PM
P0305s usually point to a plug or a coilpack. First I'd drop in new plugs (OEM/copper cores are best, then I'd swap coils - ie move the #5 pack to #3 and see if you suddenly get P0303 codes... If your coils have 100K or more on them are probably starting to fail where the spark is not hot enough under load.
Old Mar 31, 2016 | 02:02 PM
osage's Avatar
Thank you. Thank you. Will get into it.
denver005
Nov 10, 2009 12:32 AM
grosseile88
Aug 30, 2009 04:41 PM
rules
Jan 11, 2009 07:16 PM
hans_gregor
Aug 30, 2007 06:27 PM
Midnight_Caller
Sep 9, 2006 06:55 PM
