check engine light wont go off after repairs
98 V70 xc. 2.4L check engine wont go off, code p107. changed out computer, barametric, and checked all wiring. Chk eng. light wont go off. This is a friends car, posting for him. I greatly appriciate anyone's time and advice on this. I will provide any other info you need. thanks-ahead of time. Volvo's are his passion, just cant figure this one out
This could be a challenge to diagnose based on your level of expertise. (I'm assuming you have tried to clear the codes)
This code sets when it sees the sensor out of range, what you need to know is the computer gets its feed back from a 5 volt ref signal, chances are several other sensors use the same 5 volt ref, so for example if a TPS were to short out it could pull the ref voltage low and set a code for which ever sensor the computer is monitoring at a given time. Sounds kinda difficult but if you eliminate other sensors you should be able to pin point, some to look at are TPS, Fuel tank pressure sensor, A/C pressure switch, egr, hope that helps!
Fern Schmidt
2001-2013 model year V70
08-13-2013 06:43 PM
elijahs40
06-20-2011 10:32 PM
Ruskya Mafia
01-14-2011 10:54 PM
