cool wheel/tire package
Old 06-10-2012 | 03:31 PM
JDToohey98V70's Avatar
From: currently stationed in TX w/the military but from and goin back 2 Colorado soon!
Arrow cool wheel/tire package
anyone know the biggest or best setup? or other cool volvo wheels that will fit the 98 v70? whats the biggest tire u can run on a 16in wheel?
Old 06-26-2012 | 10:31 PM
Green friend 99's Avatar
There is a good article on the IPD site that should help
Old 06-27-2012 | 06:28 AM
The biggest tire on a 16" wheel? SMH Each wheel has a proper tire size. Any other size will be improper and will likely cause problems. Throwing your speedometer off, affecting handling, causing rubbing, etc.
Old 06-27-2012 | 07:17 AM
Well RSPI I'm not a moron in fact I build modified keeps so I get that! But thanks for nothing! Idk if my speedo/odometer is off and with every size wheel within reason u have a little play room and can go up and down slightly in tire size! And I wanted to know cuz I neede to buy some used wheels/tires just to get me by for a short period of time! So once again Cpt
Old 06-27-2012 | 07:20 AM
Well RSPI-- I'm not a moron in fact I build modified jeeps so I get that! But thanks for nothing! Idk if my speedo/odometer is off and with every size wheel within reason u have a little play room and can go up and down slightly in tire size! And I wanted to know cuz I needed to buy some used wheels/tires just to get me by for a short period of time and the wheels ant tires that fit my Volvo are pretty limited! So once again Cpt. Obvious thanks for nothing!
Old 06-27-2012 | 06:58 PM
Lifesgoodhere's Avatar
+1 the size to 225/50/r16 (stock rim offset)
they fit. go any bigger and you will begin rubbing, you could trim, but it would be better to change the off set.
Steve71
05-11-2015 10:22 PM
dougr
04-04-2015 03:17 PM
Henry10
07-16-2011 02:08 PM
mstrplmber
06-26-2010 05:10 PM
xc90guy
07-21-2006 12:16 AM
