Cost of a duplicate key
Old Jan 23, 2022 | 12:51 PM
Jeffs V70's Avatar
Default Cost of a duplicate key
I recently bought a 2000 V70.The car came with 2 key fobs,but one of them can only open the doors when locked.If you try to start the car with that key the engine starts-but turns off in 2-3 seconds.
Doing some checking on obtaining a second "good" key-the costs mentioned are super expensive.
So 2 questions: how does the "bad" key start the car but then turns off,and also why is the cost of buying a duplicate key so expensive?
Any advice is appreciated.
Old Jan 24, 2022 | 08:14 AM
A 2000 has an "immobilizer". There is a "chip" in the key. It's "ID" is programmed into car and if the chip is present tells the immobilizer to allow the engine to run. So you have the cost of the key, the key cutting charge, and a download using VIDA, (volvo's software download service) to tell the car to accept the signal from the new key.
Minimum of a couple of hundred dollars for a "programmed" key.
The remote - A new remote requires a different download using the same VIDA software to tell the car to accept the signal from the new remote. You cannot "reprogram" a used remote unless you have the bag, the package the remote was sold in - there is a PIN code on the package that is used during the programming process.
You can purchase a VIDA subscription and do the downloads yourself - but it requires a DICE unit. That is the interface between a CPU and your car. Info at Volvotechinfo.com
VDASH is an aftermarket software solution - it requires a DICE unit also and I'm not sure if it can do keys.
Old Jan 24, 2022 | 12:07 PM
Jeffs V70's Avatar
thanks for the good info.
volvos40dude
Feb 4, 2016 01:52 PM
NIKIGUNZ
Mar 22, 2013 09:04 PM
robretpd
Jul 16, 2011 09:33 AM
gverholek
Nov 9, 2010 06:08 PM
hess1809
Sep 22, 2010 03:41 PM
