motor swap info
Old Dec 8, 2012 | 08:52 PM
road runner's Avatar
Default motor swap info
Hi I'm new to this forum. I have a question if anyone knows if I can put the motor from a 98 S70 into a 2000 V70 ,I have a complete 98 with wire harness and ECM
Old Dec 8, 2012 | 10:25 PM
Ozark Lee's Avatar
With enough time and money anything is possible but it will be somewhat difficult. What is the engine number of each engine?
The accessories AC compressor, alternator, and power steering all mount differently but you can fabricate mounting bars and have them heliarc welded onto the block. The sensors will all be different as well.
...Lee
Old Jan 12, 2013 | 09:00 PM
turbo matt's Avatar
Remember in 1999 the 70 series went to electronic throttle bodies. unless you swap everything over including all the wiring and ecu it will not be possible.
Old Jan 27, 2013 | 11:48 AM
VTBricked's Avatar
It may not be legal, depending on your state inspection requirement on OBDII compliance.
Old Jan 29, 2013 | 03:24 PM
Barnacle Bill's Avatar
The only long block difference that I know of is on the heads. 98 has one coil. after that year the 5 cylinders incorporated the coils at the plugs. They are bolted down, the 98 will not have the threaded holes. Tap 5 holes everything else should transfer over to the donor engine from the car.
nortons
Feb 22, 2015 11:14 PM
jpirish
1998-2000 model year XC70
Oct 12, 2014 09:11 PM
nortons
Jan 15, 2014 02:00 AM
nicolaselias
Mar 24, 2011 08:48 PM
RDP3430
Mar 18, 2011 04:56 PM
