My car acceleration makes me crazy
Old Nov 24, 2017 | 01:29 PM
Samiv70's Avatar
Angry My car acceleration makes me crazy
Hello all
I have volvo v70 AWD turbo and I have problem with acceleration some times not give more 3000 prm and on the high way raod its hard to get 2500prm and the speed just 70 or 60 KM/H and today .
It's sometimes and in other times seems fine nice car .
Today I give my car high pressure on gas padel but some thing new happened the car stop when I remove my foot of gas pedal and not start normly or not start
Just when I remove air flow sensor plug its start but with some shekes on prm parameter and motor
Please tell me what is the new and old problems , and if was same causes
No chech light and no codes of OBDII
Thanks
Waiting replay please
Old Nov 24, 2017 | 06:34 PM
firebirdparts's Avatar
If the car is a 1999 or newer, you could have problems with the electronic throttle, but it can set codes if it malfunctions. The 1999 V70 had a cable-operated throttle.
About your recent problem, unplugging the air flow sensor suggests you may have an air leak between the sensor and the throttle. That is common, as these cars have a lot of plumbing between the turbo and the throttle. If any of the rubber parts fail, then the air flow measurement will be wrong. There cold be a problem with the sensor itself too, but you can check for leaks first.
Old Nov 25, 2017 | 02:45 AM
Samiv70's Avatar
Thank you for replay
but theres no air leak
if the problem of throttle ,and I change it ,do I need programming fo a new one
maru
Feb 5, 2012 04:11 AM
smithdsouza
Jan 15, 2011 07:19 PM
iluvmyS60
Apr 23, 2008 07:32 PM
WagHag
Aug 20, 2007 05:29 PM
bahroor
Jul 2, 2007 05:34 PM
