Resurrecting old fuel pump relay thread
https://volvoforums.com/forum/volvo-v70-13/fuel-relay-location-55675/
original thread link. Relay 103 is marked as Fuel Pump Relay. Requires removing (4) T-25 torx screws to access. Is there a secret hold-down clip on this relay as on 101? Do you need a special tool to remove the relay? Would it not be easier & as effective if the intent is to stop the pump from operating to pull the 20amp fuse link? |
No clips. It is rather difficult to remove because it's surrounded by other items.
Just want to make sure I don't make something that is functioning non-functional.
Have you a favorite tool from removing said fuel pump relay? When accomplishing a compression test, would removing the fuel pump fuse also serve the same purpose for halting the flow of fuel to the fuel rail & dumping it into the cylinders? Thanks for all replies. |
Originally Posted by YV1LW
(Post 508627)
1 .Have you a favorite tool from removing said fuel pump relay?
2. When accomplishing a compression test, would removing the fuel pump fuse also serve the same purpose for halting the flow of fuel to the fuel rail & dumping it into the cylinders? 2. Never did that, it's not going to be that much, just check the compression and move on to your next task. |
