Resurrecting old fuel pump relay thread
Old Feb 18, 2022 | 05:19 PM
YV1LW's Avatar
Default Resurrecting old fuel pump relay thread
https://volvoforums.com/forum/volvo-v70-13/fuel-relay-location-55675/
original thread link. Relay 103 is marked as Fuel Pump Relay. Requires removing (4) T-25 torx screws to access. Is there a secret hold-down clip on this relay as on 101?
Do you need a special tool to remove the relay?
Would it not be easier & as effective if the intent is to stop the pump from operating to pull the 20amp fuse link?
Old Feb 22, 2022 | 02:06 PM
firebirdparts's Avatar
No clips. It is rather difficult to remove because it's surrounded by other items.
Old Feb 22, 2022 | 06:05 PM
YV1LW's Avatar
Just want to make sure I don't make something that is functioning non-functional.
Have you a favorite tool from removing said fuel pump relay?
When accomplishing a compression test, would removing the fuel pump fuse also serve the same purpose for halting the flow of fuel to the fuel rail & dumping it into the cylinders?
Thanks for all replies.
Old Feb 22, 2022 | 06:22 PM
Originally Posted by YV1LW
1 .Have you a favorite tool from removing said fuel pump relay?
2. When accomplishing a compression test, would removing the fuel pump fuse also serve the same purpose for halting the flow of fuel to the fuel rail & dumping it into the cylinders?
1. Fingers, maybe a pry tool after removing relays that are in the way
2. Never did that, it's not going to be that much, just check the compression and move on to your next task.
Austin1234567
Nov 8, 2014 06:39 AM
Ojisan850
Engine & Internal
May 23, 2012 02:01 PM
moonraker
May 6, 2007 03:26 PM
browntrout
Aug 2, 2006 07:07 PM
wavewright
Apr 29, 2005 05:28 PM
