Speedo In-op
Old Feb 5, 2013 | 07:07 PM
Nomadman's Avatar
Default Speedo In-op
Hi folks. In early Nov., I bought a '98 V70 AWD, 140kmi. I put 15kmi on it by the end of the yr.. Spent the last 2 weeks in the body shop (thanks, Bambi). A few days before impact, the speedo was dead for 10 or so miles, but just once. Was fine when I drove off again. The only thing I'd done that was at all a "rarity" was to back up for a short distance. So, today while bringing it from shop, I stopped to run an errand. Started back up, no speedo. Stayed inop all the way home. I haven't driven anywhere since, so it may be on again in the morning. I saw it mentioned elsewhere here (in answer to a similar question for another model Volvo) that the "electronic pick-up wire @ the differential may be faulty". Is this a common thing and fixable at the diff., or a sign that the unit is on the way out?
Thanks for any ideas/input. I'm no wrench, so this car should be interesting. I'll have several more questions about it very soon.
Old Mar 11, 2013 | 08:33 AM
rmmagow's Avatar
I know this is an older post but... Your ABS module is probably going bad. If the ABS module is dead, speedo is affected. I know the speedo won't work while the thig is removed. Getting it rebuilt is pretty inexpensive and worth the money.
Old Mar 14, 2013 | 11:20 PM
Nomadman's Avatar
Default early V70 speedo
Thank you for your reply, rmmagow. I'm in the middle of a several-thousand-mile roadtrip with the car, and it's a given that the speedo will drop out at least several times a day. Sometimes it is from start-up, other times it just blinks off (which of course disconnects the cruise control, instantly grabbing my full attention!). Usually it will rekindle itself after I pull over, shut down, and re-start. Occasionally, it takes a time or three.
Thanks again for getting back to me on this thing. I'll be looking into a fix on my return. You know, it's been awhile since I've had a car with some personality. I'm beginning to really like this boat...err, estate! I spent today zipping up, down, and around the Colorado Rockies. Fresh struts sure make a difference!
rejeep
Nov 19, 2005 10:05 AM
oscar moncada
Oct 18, 2005 10:23 PM
volvoguy
Oct 2, 2005 06:09 PM
JT
May 14, 2005 01:42 AM
rustexpert
Feb 26, 2005 06:06 PM
