starts then dies no restart
I have a 98 v7 non turbo.
The first start of the day is fine, car idles abut fifteen minutes then dies and will not restart. The next day same issue. There is a code for p-0447. This just began a week ago. The p-0047 has been there for a few months with no issues concerning the starting. I recently replaced the pcv system because of a bad hose on it. I did not think that would fix the dieing issue but the vacuum leak needed to be repaired. Fuel pressure holds at 43 psi while the car runs, a few pounds lower with key on engine off. Tried restarting after it dies with maf sensor unplugged also iac motor and cam sensor unplugged still not restarting. Could the evap. code be the problem after this long?
