01 V70 T5, sunroof and a/c issues
So I have recently fixed a mess of problems on this lovely vehicle and everything was great until my sunroof started to act up. When I press the switch to auto open it it stops after moving partially the it only moves slightly when I push it again. It does the same thing going forward and some times the switch doesn't do anything. It does start working properly but eventually reverts back to the same thing. For my a/c issue, it blows cold but every once an while when I turn on the a/c or even just turning on the blower I feel the air come out of the vents but then I hear a little motor and the air stops like I pressed the manual circulation button. I can hear it blowing but it's like it keeps closing itself off. If I turn the air off and then back on I feel it again but it closes off again. It's not all the time but annoying to say the least. Any help is greatly appreciated!
On the first Gen V-70's I have had a couple cars experience having one of the air intake doors stuck. Thus they had a certain mode where you didn't get any air, but the fan is still running. It may be that turning on A/C is sending it into recirc mode, which should close the fresh air intake. If the recirc door is stuck then that is what is stopping the air.
You can probably get to the stepper motors moving these doors by pulling out the glove box. I am just guessing.
