2001 2.4L V70 Turbo Stalls When warmed up, multiple codes
This thing was running excellent until about 3 days ago, when cold it starts and runs fine but when it warms up all hell breaks loose.
It started stalling at stop lights. When in gear I have to juggle between the break pedal and gas pedal to keep it from stalling, when in neutral the idle surges between 1,000 to 800 RPM.
What has recently (within three months) been done to the car;
1. Xemodex ETM installed
2. New Bosch MAF installed
3. fuel pressure tested at the rails, can't remember what it was but was remember that it was good.
4. Fuel filter changed out.
5. checked gas cap and it clicks on ok and tight.
The gang signs it is throwing up are these;
P0455 - Large evap system leak
P1633 - Faulty speed signal, (ABS?)
P1175 - Long term fuel trim lower unit?
P1238 - Turbo charger control system fault
P0171 - System too lean bank 1
P0121 - Throttle pedal position sensor
Could a bad O2 sensor be causing all these faults?
