2001 V70 compressor on and off with ac off
Old Oct 7, 2013 | 10:10 AM
RikoOrtiz's Avatar
Default 2001 V70 compressor on and off with ac off
Just bought a 2001 v70 24T with 150000 miles but idle are up and down plus compressor clutch go on with Ac control module in off position. Any help??? Read something about low Freon but is my Ac bottom are off should be never go ON Right??? Other said something about Ac control module but don't want spend money unnecessary. Any help are welcome...
p.s
Sorry about my write English are really bad.
Old Oct 11, 2013 | 10:24 AM
webbch's Avatar
Defrost setting uses A/C as well. Idle hunting can be a number of things - any check engine codes to go on?
Old Oct 12, 2013 | 09:59 AM
RikoOrtiz's Avatar
Any code only srs light ON. If defrost are ON could be ON the compressor?
Old Oct 13, 2013 | 09:29 AM
webbch's Avatar
Yes, if defrost is on, it will run the A/C compressor, even if the A/C is off.
Old Nov 27, 2013 | 08:16 AM
CPOman's Avatar
The a/c compressor clutch may need to be adjusted. I've seen where you insert some washers between the a/c compressor clutch and the housing so it doesn't disengage when it's under load.
Old Nov 27, 2013 | 08:24 AM
If the compressor is cycling I would think the freon is low.
Old Dec 17, 2013 | 03:47 PM
webbch's Avatar
Shims are normally REMOVED (or replaced with thinner shims) if the clutch is failing to engage, and generally only added if clutch is rubbing on something.
Subvol
Dec 11, 2011 06:56 PM
lcocke
Aug 31, 2011 06:51 PM
sghokie
Jul 25, 2011 05:00 AM
Rvillev70
Jun 28, 2010 08:51 PM
tcrossley
Dec 15, 2008 03:42 PM
