2001 V70 front wheel bearing hub bolts
Old Aug 24, 2014 | 08:48 PM
Cheaplabor's Avatar
Default 2001 V70 front wheel bearing hub bolts
I am gathering parts to change a front wheel bearing on my girlfriends 2001 V70 base front wheel drive wagon.
I plan on using a Raybestos 713194 hub assembly but it appears that it doesn't include the four mounting bolts. A few sites show that the external torx head bolt 1387892 goes with the hub up to 2000. Will these bolts work on an '01 car? Or does anyone know the right part number for 2001 and up cars?
Also, long shot here but does anyone know the thread pitch on these bolts? I think they are an M12x55mm long. If they are a normal thread pitch like 1.5 I can probably just get some bolts from work instead of having to order them.
Any help is greatly appreciated!
Old Aug 26, 2014 | 09:45 PM
oragex's Avatar
Usually you get those bolts at the Volvo dealer for around $50 for all five. Careful when removing the hub, suspend the axle with a wire so it doesn't hang free - or it might split open
Old Sep 2, 2014 | 08:06 PM
Cheaplabor's Avatar
In case any future people stumble upon this thread with the same question I had...they are just a regular flange head M12 course thread (1.75 thread pitch) bolt that are about 55mm long.
I grabbed a set out of the bolt bin at work that were 50mm and were just a touch shorter than what was in there. Which was fine since the stock ones stick through the hub about 5mm.
The originals were only grade 8.8 and I put in 10.9s so I even upgraded them for way less than the dealer would have charged.
geoduck
Jul 15, 2016 04:18 PM
puxnstx
Dec 13, 2014 11:36 AM
rokkmann
Jan 10, 2011 01:59 PM
halcyon419
Nov 20, 2009 12:36 AM
