2001 v70 T5 Rough idle
Old Apr 26, 2017 | 12:03 PM
Magnusson's Avatar
Exclamation 2001 v70 T5 Rough idle
Hello everyone, I am currently having an issue with the v70 that I have as the car idles roughly as I took a closer look into the problem after replacing the oil trap and hoses the go through out the car from the oil trap itself. I reset the check engine light to see if I can get a P code from the car if it finds any issues and to see where the problem may lie. To give a rough estimation of what the rough idle look like to help get me an insight here is a youtube video of what the car is doing either at cold start up or even at temp.
Old Apr 26, 2017 | 01:10 PM
ES6T's Avatar
If there are no vacuum leaks, I would clean the throttle. It may need replacement though
Old Apr 26, 2017 | 03:38 PM
Magnusson's Avatar
Question Codes
for sure that I would clean the throttle to make sure and looking around for vacuum leaks if I see any obvious signs. now for the error codes that are given to me
Pending Codes
P0300 Random/Multiple Cylinder Misfires Detected
P1133 O2 Sensor Heating Circ.,Bank 1+2-Sensor1 Electrical Malfunction
End of Pending codes
Stored Codes
P0137 O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
End of Stored Codes
I check all of the coils as I unplugged each one individually to see as it would affect the engine. all of the coils that I unplugged did in fact affect the engine performance while idling. I removed the MAF sensor plug to see if it affected the performance as it did as well.
I am really confounded at this issue atm and any help would be appreciated!
Old May 2, 2017 | 05:51 PM
Magnusson's Avatar
Lightbulb The Solution
I finally figured out the issue as the Breather Hose and the MAF Sensor was completely gone and non existent and while I was at it to have the Timing Belt and tensioner pulley since the last time was covered in oil shortening it's life and I hope this will help out a lot of people on getting the rough idle issue and random misfire's done and delt with.
nkinkade
Feb 28, 2014 08:49 PM
MilesDunis
2001-2013 model year V70
Apr 5, 2013 06:32 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
