2005 V70 shuts off while driving?
Old Sep 13, 2017 | 04:41 PM
higgy baby's Avatar
Default 2005 V70 shuts off while driving?
Hello fellows-
Help me if you can with where to start on my car. I have an 05 V70 that has been running fine. I have had it 2 years- no issues. Today, my son was using it and it shut off while he was driving. He was arriving at his destination so he let it sit for a while. When he started back home...it shut off 5 more times on the hiway. Each time he was able to stop- put it in park- turn the key, and it started right back up.
It runs fine....but today it shut down 6 times.
What could be the issue?
Thank you
Old Sep 15, 2017 | 02:28 PM
pierremcalpine's Avatar
$10 says that's the fuel pressure regulator if you have one on the fuel rail.
Old Sep 15, 2017 | 03:53 PM
higgy baby's Avatar
Thanks for your reply....
I put it in the shop.....they say its fuel/air system.
They want $1300 to fix it! I really have no choice.
Old Jun 18, 2019 | 08:52 AM
higgy baby's Avatar
Well- the phantom returns.
Had this issue repaired about 2 years ago- cost turned out $1235. Looking at paperwork- it appears they replaced everything dealing with the pvc?
This past week I have had this issue 2 times now. ........ driving fine and then the engine shuts down while driving. I'm wondering if there could be water/ trash in the gasoline???
Old Jun 19, 2019 | 06:21 AM
Georgeandkira's Avatar
If you're in the USA the ethanol in our gas precludes the chance of water (and therefore much chance of gunk) being in your tank.
Your car still has a separate fuel filter. Changing it is the perennial first step.
Cleaning the MAF (with MAF cleaner spray-allow to dry) is also super basic and you might get lucky.
Cleaning the ETM (throttle body) is another thing any people can do.
Read your fuel pressure. It's a basic test most shops and do-it-yourselfers can perform.
Have your car read at a dealer using their VIDA/DICE.
Old Jun 19, 2019 | 08:54 AM
higgy baby's Avatar
Thanks for the answer.....but I put the car in the shop late yesterday. We'll see what they come up with.
And yes- I have always purchased blended gas- 10% ethanol. But now I see- the cost of repairs far outweighs the extra cost of pure gasoline.
Old Jun 19, 2019 | 09:00 AM
higgy baby's Avatar
Thanks- I put the car in the shop late yesterday- don't really have a place or the tools to do it myself.
But I do believe the issue was trash in the gas, as I do burn 90/10 blended. Perhaps I should switch to pure gas?
Old Jun 21, 2019 | 06:57 AM
Unless you went to a "real bad" gas station I wouldn't suspect fuel is your problem. I've run 90/10 gas in three V70's over 15 years now.
Did you mention the fuel filter to your mechanic? A new one might allow some performance improvement if the old one was clogged.
Do get back to us. Is your shop a foreign car specialist? Do they know Volvos?
Old Jun 21, 2019 | 09:21 AM
higgy baby's Avatar
Yes- the shop specializes in foreign cars including Volvo. I did mention the fuel/filter when I took it in. I have not heard back yet.
When they do call....I will report it here.
The cars performance is great.....runs smooth, gets good mileage- except when it shuts off-
Old Jun 28, 2019 | 08:23 AM
higgy baby's Avatar
Okay- supposed to get my car back today? (2005 V-70 shutting down while driving)
We'll see?- their diagnosis said fuel pressure sensor regulator. Once I get the paperwork I'll post what all they did.
Cost estimate ~ $650. (I had some extra work done to drivers door too-window would not go up or down)
Old Jun 28, 2019 | 08:19 PM
higgy baby's Avatar
Got the V70 back this evening- Fuel Rail Pressure Sensor is what they replaced- total cost was $622.93, and $152 of that was for driver door window.
Car drove fine coming home- I hope its fixed.
Old Jul 1, 2019 | 12:48 PM
higgy baby's Avatar
Update: When, when I got home I noticed a buzzing sound. Couldn't hear it while driving- radio was on also. But bottom line- i thought it was fuel pump- sound actually coming from fuel tank!. So- got it back to shop today and they said it is the fuel pump. I had to leave it with them- waiting on a rack to put it on.
Don't have a diagnoses yet or a price to repair. Hope its not bad?
Old Jul 5, 2019 | 06:50 AM
Blackeagle's Avatar
Had a similar problem but on my stepsons BMW 525TDS, shut off when driving, turned out to be the big bunch of keys hanging off the ignition key, constant swing affected the lock and wore it so that it eventually cut out from time to time, I remember one of the big Japanese bike makers had that problem too and actually issued a service bulletin on it, but that was over half a century ago, in my youth.
If it is the fuel reg, I had that on my performance VW air-cooled, I fitted an after market regulator, (with a gauge), end of problem for under $60
Old Jul 5, 2019 | 10:16 AM
higgy baby's Avatar
Update 2: finally got a call from shop Wednesday eve. They say fuel pump is definitely bad- replacement will be right at $1000.
Sad part here is I had just had it in the shop to repair cause of it shutting down while driving- think is was $623?- when I got it back the fuel pump was making a racket- wonder what caused that? So now this last trip will wind up costing me a total of $1623........ I think they screwed up.
Not going back to that shop. Might be time to start looking for another ride?
Old Dec 6, 2019 | 07:03 AM
higgy baby's Avatar
Update #3......crapola!!! V70 still shutting down on me. last post on this was in July. Well I finally found another shop- put the car in back in Oct. They kept it for just over 2 weeks....finally diagnosed some wrong parts from last shop repair. They changed out fps and replaced a coil? looks like "2# ion coil"?....Cost $585. I have had it back near 2 months now- no issues. I think its finally fixed. Thank God.
Old Feb 19, 2020 | 07:38 PM
higgy baby's Avatar
Update #4.....
All good, this car has not missed a beat since last repair back in Oct 19. I believe I have finally found the right repair shop.
Old Oct 4, 2020 | 12:02 PM
  #17
higgy baby's Avatar
It's been a year now since the last repair....and it has not missed a beat.
Old Oct 9, 2020 | 09:14 AM
  #18
mygreent5's Avatar
the first shop screwed you..haha
It is good news the car run fine now.
Old Oct 22, 2020 | 10:37 PM
  #19
Tinkerbell's Avatar
You might want to invest in an OBD II pocket scanner. I prefer the Bosch. You can narrow down possible problems really fast with one.
Old Oct 23, 2020 | 09:53 AM
  #20
higgy baby's Avatar
Thank you Tinkerbell.....I just might look into that.
