2008 Volvo V70 won’t start
Hi all - My 2008 Volvo V70 wouldn’t start last night.
The lights come on the seatbelt warning chimes, the stereo comes on, but the when I press the ignition button all I hear is a dull buzz and a click. The engine makes no noise at all. https://cimg7.ibsrv.net/gimg/volvofo...0ac574379.jpeg Last night: I connected a trickle charger to the battery over night - no luck this morning. Today: I tried jumped it - no luck. I plugged in my OBD2 reader - no faults I replaced the battery entirely - no luck. Any suggestions? my experience is exactly the same as this woman in youtube was experiencing. |
sounds like the battery is kaput to me
Originally Posted by Smith Volvo
(Post 452523)
Marty |
This is weird. So I have a new battery installed, and I’ve been charging it, and my smart battery charger says the battery is full, but I still get low battery warning msg on the dash. Huh...
Could this be a loose wire somewhere? thanks |
Do you guys think the most likely issue is?
A) Faulty negative battery cable? Is this unlikely since the car has Power, Lights and even headlights work? https://cimg8.ibsrv.net/gimg/volvofo...19ee8b9fc.jpeg B) faulty ignition switch? Is this inside the Ignition module? https://cimg9.ibsrv.net/gimg/volvofo...b7ce6f03e.jpeg C) faulty ignition module? Does this require new keys etc? https://cimg2.ibsrv.net/gimg/volvofo...122d665af.jpeg or D) faulty Starter https://cimg3.ibsrv.net/gimg/volvofo...acfc63eb7.jpeg Any help would be great, I’d love to have a go at this before having to tow to Volvo dealership and get hosed. |
Originally Posted by Martin.greenwood
(Post 452539)
Yes - I assumed so too, but I replaced the battery, and still the problem continues.
Marty |
Originally Posted by Vida
(Post 452652)
You have an electrical issue. A module is Either bringing the CAN network down or a faulty pin, corroded terminal, fuse, etc. Don't assume though, it needs to be confirmed. You would need VIDA to Check for codes, a regular scanner will not work.
https://cimg1.ibsrv.net/gimg/volvofo...76cee4b80.jpeg We’ll find out soon. |
Turns out it was the Starter. Got a new one, works great again.
