Can't get out of Park
Yes there is an interlock. It's a separate plug in part, on a bracket and it contacts the brake pedal hardware.
It's down low. I saw it in a brake video. See if you can locate yours and if it's plugged in.
I just tried to find the video and failed. One post I read mentioned the actual lock part is at the base of the shift lever and can be rendered sticky by spilled beverages. A fellow suggested to another guy with your problem that a sharp rap downward on the lever might free it up.
Possibly gain access by removing the console cover and see if it can be removed or set aside securely?
Last edited by Georgeandkira; Feb 16, 2020 at 02:34 PM. Reason: failed finding video
