Drivers side back door, inside latch not working
Old May 19, 2015 | 06:31 PM
mafraziersr's Avatar
Default Drivers side back door, inside latch not working
Even though the child lock is off, the inside door handle will not work. Ideas?
Old May 30, 2015 | 04:10 AM
stop_at_willoughby's Avatar
There is a harness that sits in a plastic bracket. When you pull on the on the door it pulls on a cable to open the door. The plastic bracket that holds it in place more than likely is broken.
I had this happen in my 02 s60 about a year and a half ago. I checked out forums like this and videos for taking the door pannel off. Saw the problem I did a hillbilly fix with a short screw to tighten everything up and keep the harness back in place since the plastic bracket holding it failed.
Flow313
Nov 26, 2014 08:09 PM
Luis Vale
Mar 23, 2014 06:28 PM
sylvkaiko
Mar 4, 2013 02:44 PM
Aesthetikz
Nov 17, 2010 10:46 PM
volvoz
Sep 12, 2005 08:38 PM
