Installed K&N Filter now runs like s#@t!!!!!
Old May 2, 2012 | 08:09 PM
grosseile88's Avatar
Default Installed K&N Filter now runs like s#@t!!!!!
Just dropped in a standard K&N air filter into my 2001 Volvo V70 T5 this morning. Started it up to head to airport and it was running very rough. Drove approx 8-10 miles to airport and check engine light came on, acceleration was horrible and was running very rough. What happened??? Did I screw up Mass Air Sensor or is something else going on??? I heard it takes a a bit for ECM to recognized increased air flow but this seems really strange. Car is in airport for a few days so any advice would be much appreciated????
Thanks!!!
Old May 2, 2012 | 08:24 PM
fstaslp's Avatar
I had issues at first. First, make sure that the turbo inlet pipe is over the inlet of the turbo.
That corrected my stalling on startup.
Then make sure the connectors are tight on the BCS and MAF.
Then I was still having over boost issues. It would spike to 15 lbs and then fall to 5 psi. I took it to my indy shop and they couldn't diagnose it.
I fixed it by doing a hard reset on the ecu:
1) remove negatove battery cable and then the positive.
2) zip tie the conectors together (not to the battery)
3) pump brake pedal a few times and let it sit for 20 minutes
4) reconnect positive then negative terminals
Should be good to go. At least that worked for me and it was 1500 miles ago.
I am going to make it a habit to reset the ECU when ever I make changes to the air system.
Also, Make sure you didn't pinch a vacuum line when you reinstalled the airbox lid.
Old May 2, 2012 | 11:40 PM
migbro's Avatar
Thanks!!!
Toss it and put the stock air filter back in. I'm amazed that anyone still buys these POS. There is no increased air flow on a street vehicle. All you get is more dirt in your engine oil.
Old May 3, 2012 | 11:22 AM
Yeah I am afraid that the perceived performance benefits are not worth the hassel! If I reinstall stock filter hopefully everything return to normal???
Old May 11, 2012 | 09:43 AM
Took to Autozone to pull error code, turned out to be the #4 cylinder was misfiring. I changed plugs a few days before installing air filter and one of them went bad. Swaped out plug and she is running like a champ! I left K&N filter in place.
KLSC
Jul 29, 2014 09:44 AM
EdwardMowinckel
May 1, 2014 05:28 PM
1993 240
Oct 18, 2012 11:16 PM
Dgottshall
Jan 13, 2010 07:28 PM
