Issues with keyfob
Old Jun 6, 2022 | 10:40 AM
Zwayna's Avatar
Default Issues with keyfob
-09 v70 and its been acting up lately. Batteries have been changed first thing but didn't do a thing.
So the issues are that occasionally it won't open or lock the doors - or just one or 2 doors - and also sometimes car wont accept the fob and ao won't be able to start. Or will not give the fob out.
At first we thought it was because car battery voltage was 11.88V but since we have charged the battery we have driven only once without issues.
Old Jun 6, 2022 | 11:02 AM
You probably have a bad ignition switch causing the key insertion, removal and start problems. The slot you put the key in. Unfortunately that part is a module and requires a software download using VIDA is required to make a new one work. I have replaced a few for that problem.
A good first step would be a scan using VIDA or a compatible scan tool to be able to diagnose the problem. I trust you have the same unlocking problems with both your keys?
Old Jun 6, 2022 | 11:29 AM
Zwayna's Avatar
Yeah issue is with both keys.
Have to say sounds kinda pricy issue. Ill ask local repair shop about the diag and hope it's repairable.
Will get back later when ill know more.
Old Jun 6, 2022 | 11:45 AM
They will need a VIDA subscription and a DICE unit to be able to "program" the new ignition switch module to the car if determined to be the problem.
GJGadzooksJr
Canada, Over Seas & Elsewhere
Oct 20, 2021 01:48 AM
Cathal Keaveney
Dec 3, 2019 04:17 PM
Shane Walls-Harris
2001-2013 model year XC70
Sep 18, 2017 04:22 AM
Ag0
1998-2000 model year V70
Apr 3, 2017 09:37 PM
