Low Battery Voltage - Message
Old Nov 6, 2014 | 04:21 AM
Laptoploon's Avatar
Default Low Battery Voltage - Message
Hope someone can help with this...
Driving my granddaughter to school this morning, and the little red triangle popped on and 'Low Battery Voltage' appeared in the message window.
Got her to school OK and on arrival, turned the engine off and immediately restarted - no message.
Was at the school for maybe 20 mins, started the car - no message.... 4 miles down the road, up it pops again. Stopped for petrol, started the car - no message.... once again, 4 miles along and it pops up again.
During all this all the electrics seem to function as they should but I did try and shut off everything I could, including turning the light to sidelights.
When I arrived home I left the car running and metered the battery 14-15 volts - turned it off and metered it again - same. Did three false starts to try and drain some juice out of the battery, same meter reading.
Thoughts please..?
Old Nov 7, 2014 | 12:00 AM
damien360's Avatar
What year?
Old Nov 17, 2014 | 07:17 PM
geraldc70's Avatar
Same thing happened to me a few months ago, it turned out to be a voltage regulator, its a black box attached to the alternator. The alternator has to be taken out to change it so just go ahead and change the alternator at the same time.
Old Dec 23, 2014 | 11:45 AM
tony1963's Avatar
If you catch this early enough, you can change the voltage regulator without replacing the entire alternator. However, if you fry the alternator and the bearings are making noise, change the whole thing.
volvos80t62011
Sep 28, 2016 10:00 PM
catlurver
Apr 28, 2013 04:28 PM
MarksS60
Nov 30, 2010 04:52 PM
gcoladon
Nov 28, 2010 10:23 PM
nawlinds
Sep 25, 2008 10:23 AM
